site very slow
Started by lil chris, January 07, 2019, 08:36:53 PM
austinbob
Quote from: dannyboy on January 22, 2019, 07:18:14 PM
Same here, but the 'slowness' and 'time outs' are very intermittent.
Same here.... But not really too much of a problem.  :)
Bob Austin
Log in page took 58 seconds to load and I've had 6 time outs in the last half hour. Just when I think of giving up for the evening it starts motoring again ::)
Pah. Spoke to soon as it timed out before accepting the post. Night
Railwaygun
#17
 :helpneededsign:why not check where your signal ios coming from as it leaves the NGF server and travels via a number of nodes to your PC. my access is slow tonight (150mb pipe)
Windows users can use traceroute  to do this -
Using Traceroute
Traceroute is a computer network diagnostic tool for displaying the route (path), and measuring transit delays, of packets across an Internet Protocol (IP) network. This section shows how to run Traceroute, and how to interpret the results.
Running Traceroute
To run the Traceroute utility, proceed as follows.
    Open a Windows Command Prompt window.
    At the command prompt, type, tracert ngaugeforum.co.uk
to examine the the domain name and extension that you would like to trace a route to).
It may take a few seconds to respond, but this command will give a traceroute from your computer to the destination you selected.
Note:
You can interrupt Traceroute at any time by holding down the CTRL key, and pressing C on your keyboard.
MAc users can use network utility App.(search with spotlight)
i get these results this evening
Traceroute has started...
traceroute to ngaugeforum.co.uk (209.42.193.165), 64 hops max, 72 byte packets
1  **************  2.117 ms  1.450 ms  1.935 ms
2  10.86.240.1 (10.86.240.1)  9.969 ms  11.709 ms  12.821 ms
3  brnt-core-2b-xe-231-0.network.virginmedia.net (62.252.115.201)  9.136 ms  10.522 ms  9.059 ms
4  * * *
5  * * *
6  m686-mp2.cvx1-b.lis.dial.ntli.net (62.254.42.174)  12.893 ms  11.714 ms  12.274 ms
7  * * *
8  uk-lon01b-ri1-ae25-0.aorta.net (84.116.136.102)  17.244 ms  19.723 ms  17.229 ms
9  195.66.226.116 (195.66.226.116)  16.795 ms  17.605 ms  17.858 ms
10  bbr2-xe-2-1-0.lon003.pnap.net (216.52.199.34)  24.212 ms  22.545 ms  24.006 ms
11  core1.be3.ams004.pnap.net (216.52.199.50)  18.258 ms  18.699 ms  19.057 ms
12  border3.ae2-bbnet2.ams004.pnap.net (95.172.78.70)  23.073 ms  18.567 ms  18.013 ms
13  edge1.ae1-edgenet.ams006.pnap.net (64.74.80.18)  19.126 ms  18.749 ms  20.929 ms
14  giglinx-102-edge1.ams006.pnap.net (95.172.88.2)  21.095 ms  19.809 ms  22.047 ms
15  ssd06-nl.privatesystems.net (185.158.84.6)  21.095 ms  20.536 ms  23.152 ms
16  host.ngaugeforum.co.uk (209.42.193.165)  20.086 ms  17.818 ms  18.338 ms
so your electrons travel a long way round!
if you have problems run traceroute and post the results here - it will help @Tank  decide where the problems may lie ( not necessarily at NGF Towers!
NGF Military threads
10mm / N armour Threads
weave
Hi Railwaygun,
Have absolutely no idea what you are talking about but thank you as might help someone else in need. Just leave me, save yourselves!
I'm getting slow, very slow, forbidden, slow again, fast, fast, fast, this site cannot be accessed, back on slow, OK, slow etc. for the last 4 days at least. Not moaning yet but just letting the powers that be know.
Don't worry, the fridge is right behind me  :D
Cheers weave  :beers:
PS Windows 7 PC.
Tank
I cannot replicate any of these problems.  It's fast paced for me. :confused1:
daffy
My access and times have been okay to good most of the time. When the site is slow, so have others been.
It's cold, so I'm blaming frozen leaves on the line. :D
Dorsetmike
When it's running slow I note that the progress info box (bottom left when waiting for site to open) spends most of its time showing "Waiting for TLS handshake" this also shows when opening a thread.
Worst I had yesterday evening was over 1 minute to open the site followed by a further minute to open each thread
[smg id=6583]
Lawrence
Lots of "This site cannot be reached" today and lots of reloads trying to get in  :(
weave
https://simplysociallyyours.wordpress.com/2012/11/26/it-takes-2-seconds-to-say-thank-you/
Tried Googling 'it takes 2 and half minutes to say thank you'. The only thing that came up was 'N Gauge Forum'  :D and then I couldn't get in for a while  :doh:.
Am still sticking with it, obviously, but it's getting nigglier and nigglier.
Hope it's still 'British Rail - We're Getting There!'
Mito
Problems here too. "establishing a secure connection". timed out and just very very slow. It's almost unusable tonight.
guest311
Tank
I put in a Ticket request with the host.  VERY slow tonight.
daffy
Even the usually unflappable Daffy is giving up trying to play here tonight, so hopefully the Host will react positively. thanks Chris.
Took me about four minutes to open, read and reply on this thread.
Worst performance I've noticed to date.  Must be everyone logging in to read the disappointment about the Pacer  :D
My patience ran out a couple of days ago. I'm getting more time outs than success at present. I think it's the worst it's ever been :unimpressed:
Total Receipts: £30.00
Below Goal: £70.00
30%
