class 73 chassis / body compatability
Started by bluedepot, April 05, 2018, 08:03:51 PM
bluedepot
hi everyone
don't know if someone here tried it, but if you put an old version class 73/1 body on a newer style dcc ready class 73 chassis, will the lights work?
cheers
tim
:NGF:
Tank
Annoyingly, no!  I swapped a couple of DCC ready chassis with someone and I didn't realise.
Mr Sprue
And again NO!
On a more polite note both chassis are different. The later body has a small pc board fitted with the pickups further to one end, unlike the early body which just has a resistor and the pickups fitted in the centre.
bluedepot
ahhh ok
well that answers that then!!
cheers both
tim
As I understand it the old bodies have springy pickups under the roof which contact the split chassis - what does the newer design have? Are the lighting/cab detail assemblies also different?
This is an old style bodyshell I think?
Mr Sprue
A pc board and smaller springy clips two thirds or more to one end.
Mr Sprue
Quote from: ntpntpntp on April 05, 2018, 08:36:42 PM
Yep that's the earlier body.
This is the later one...........
Total Receipts: £98.45
Below Goal: £121.55
