GeeBee
No work to report on Martini Holt or Wotcanappen just can't get motivated at the moment  :sorrysign:
Quote from: GeeBee on September 17, 2016, 11:55:26 PM
Not surprised after your work at the show, Graham. That must have taken its toll on your physical resources.
chalfytich
chalfytich
Hopefully your motivation will return very soon Graham.
GeeBee
Quote from: newportnobby on September 18, 2016, 08:31:02 AM
I don't think it is physical I seem to have switched off all enthusiasm for modelling I just feel like sitting down and vegetating perhaps after this operation I will have some more get up and go at the moment it has got up and gone
MinZaPint
Hi Mick, track plan here, which unfortunately shows how long I've been procrastinating  :-[
http://www.ngaugeforum.co.uk/SMFN/index.php?topic=1724.msg205002#msg205002
and a rather distorted panorama
so that's all the trackwork laid, all tested electrically so a thorough clean and then make a start on the scenics. Cheers for now David
Cogito Sumere potum alterum
Thanks, David.
Everything looks very neat and well laid out, especially the under layout shelving :thumbsup:
Croxy
Total layout disaster........came home this evening to find that a fitting on a toilet had broken.....right above where my layout is in the basement.....so on top of whatever other water damage there is the layout is done.........everything soaked.......will have to be totally scrapped.......pulled up all the points and there motors....in tubs of rice to hopefully save them.....will be quite a while before I start over........
:veryangry: :veryangry: :veryangry: :censored: :censored: :censored: :censored: :veryangry: :veryangry: :veryangry: :veryangry:
If you like it run it......
Oh no! Most certainly a disaster of major proportions!
My condolences, mate.  :(
The points and track should be salvageable, not sure about the electrics, though.
Sorry to hear this.
George
My condolences too.
I would expect that your electrics should be OK as it was fresh water that soaked them I assume. Make sure you dry them out thoroughly before passing a current through anything.
Catastrophe!
So sorry to hear that, Croxy, and hope you manage to salvage as much as possible :(
daffy
Quote from: Croxy on November 06, 2016, 05:19:27 AM
This is so terrible for you. I can imagine just how you must be feeling.
As well as using rice, some of those water absorbency crystals used for damp places will be more efficient. I used some recently to dry out an iPhone that had dropped into a loo (don't ask!) and it was successful. I just placed the item in a sealed box resting on a piece of wood on top of a thick bed of the crystals for 48 hours.
These are the ones I use but others are available:
http://www.lakeland.co.uk/20934/Moisture-Trap-Refill-Crystals?gclid=CPjfucLwk9ACFVU_GwodEh0MdQ&src=gfeed&s_kwcid=AL!49!3!105381800309!!!g!43851818465!&ef_id=WB8AKwAABK-bUCkb:20161106100427:s
daveg
That's really bad luck.
Do hope you can rescue much of the trackwork and some if not all the electricals.
Any chance you can get some financial help to replace the lost kit via insurance?
Keep us posted.
So sorry to hear about this.
It would be good if your insurance coughs up. Worth a try ?
