Author Topic: Detailing 3f and 4f locos  (Read 3503 times)
Offline lil chris
« on: December 05, 2017, 11:08:51 PM »
I am planning on detailing 3f/4f locos, one is a Union Mills 3f the other  GF 4f. Can anyone advise on the back of the cab is a handrail what size brass rod do I use for that, I have some .5mm is that too big.
Online PLD
Re: Detailing 3f and 4f locos
« Reply #1 on: December 06, 2017, 07:52:27 AM »
0.5mm is a scale 3 inches. Think - could you comfortably hold on to a handrail that large?
Most handrails are in the region of 1.5 - 2 inch diameter - a scale 0.25 - 0.33mm. The wire I generally use is 0.31mm...
Offline lil chris
« Reply #2 on: December 06, 2017, 10:03:43 AM »
Thanks pld that's what I thought,I was looking for 0.3mm but could not find any in the shop.
« Last Edit: December 06, 2017, 10:04:51 AM by lil chris »
« Reply #3 on: December 06, 2017, 10:31:06 AM »
I've found a good source of thin wire from SWG20  (0.9mm) to SWG34 (0.234mm) silver or gold finish, reels of 9M £1 also reels of 22M (sold for stringing beads in jewelry making)
https://www.therange.co.uk/hobbies-crafts/hobbies/jewellery-making-supplies/cords-and-wires/trimits-beading-wire#613451
a handy SWG conversion at
https://www.rapidtables.com/calc/wire/swg-to-mm.html
Offline Shiney Sheff
  • N Gauge Society Number: 23792
« Reply #4 on: December 06, 2017, 10:40:55 AM »
This is the one I use at 0.25 dia, they also sell the handrail knobs to go with it.
http://www.nbrasslocos.co.uk/fitbr.html
Bob
« Reply #5 on: December 06, 2017, 12:06:13 PM »
Compare the price £2.20 for 480mm (4 pieces at 120mm) against £1 for 9M ;   9M/480mm = 18.75  so £2.20 * 18.75 =  £41.25.
I rest my case.
Offline lil chris
« Reply #6 on: December 07, 2017, 12:23:50 AM »
Thanks guys I had already put a order into Nbrass for a few bits. Today I managed to pick up some florist wire for use with d&g couplings, plus I found some 0.35 piano wire in a model shop on my travels which was only coppers. No rush,
I have plenty to do over Christmas this year instead of watching the same old tosh. lol
Online Atso
« Reply #7 on: December 07, 2017, 08:52:39 AM »
I use ten thou guitar wire for my handrails. Not as easy to work or bend but I find the final result is more robust being made out of nickel coated steel.
Offline lil chris
« Reply #8 on: December 07, 2017, 11:05:15 AM »
Thanks Atso and everyone else. All these different  sizes are confusing me,only just getting used to metric. I will probably use the h/rail from n brass he as already posted the order off too me. The thing that confuses me is the pictures I have of 3f's the h/rail down the side of the boiler looks very large compared to the ones on the cab.
Online PLD
« Reply #9 on: December 08, 2017, 07:47:09 PM »
That's because on one side it's not a handrail!  ;)
On the driver's side of the loco you have the ejector pipe running along the side of the boiler (it should end in a junction with a vertical pipe running down to the footplate). There is a normal sized handrail in the equivalent position on the fireman's side.
Offline Vanders
« Reply #10 on: December 08, 2017, 09:36:02 PM »
I rest my case.
Sure but how many handrails are you planning to make?
« Reply #11 on: December 08, 2017, 10:11:24 PM »
Plenty of uses for thin wire, I've never filed off cast hand rails in over 40 years of N gauge; if a new loco already has hand rails that's OK, but fiddling with hand rail knobs and wire is not my scene.
Offline lil chris
« Reply #12 on: December 20, 2017, 12:11:23 AM »
Like I have said previously I am planning on detailing my Union Mills 3f,and also plan to renumber some of my other locos. I have bought numbers from Fox Transfers 8" and 9" numbers plus early lions. The lions look small compared to the ones already on, maybe I have bought the wrong lions, what date did the lion emblem change. Also any tips on fitting the seperate numbers onto the loco cabside and getting them straight, I have noticed in the leaflet they sent me they do sets of numbers, that might be a easier option. I know it is advisable to have a gloss finish too put the transfers onto, I have not done any transfers for years since I built the old plastic kits.
« Reply #13 on: December 20, 2017, 09:52:56 AM »
I reckon the likes of @Atso @Dr Al @Ozymandias are the guys likely to help with renumbering
(apologies to anyone missed)
Offline Dr Al
  • Trade Count: (+49)
« Reply #14 on: December 20, 2017, 11:45:07 AM »
The UM crests are far too large, so you likely have the correct ones. Look at prototype pictures (generally lots on Flickr that google image search doesn't find).
The crest changed to the latter style in 1957, though lots of the earlier style were seen later than this (particularly on lesser locos) as they weren't changed until a loco was shopped and needed a repaint. Some locos never got the later crest, so prototype photos are again invaluable.
Yes, better to gloss the surface, then seal in the desired finish (normally matt for a freight loco like 3F). If patch painting the cabsides only then it's probably wise to gently sand the area flush with a fibreglass pencil to ensure the area is smooth, and the raised original printing isn't seen through the overcoat.
In terms of alignment, you can use a piece of masking tape to provide a bottom line to align the decals along. Also, start with the middle numeral of the 5 and work outwards to get the lateral positioning correct.
Usually 9" is the correct size, some smaller tank locos used 8", and some larger locos had 10" applied (and odd Scottish region depots applied 10" to everything).
“We have also arranged things so that almost no one understands science and technology. This is a prescription for disaster. We might get away with it for a while, but sooner or later this combustible mixture of ignorance and power is going to blow up in our faces.” – Dr. Carl Sagan
February Goal: £250.00
Total Receipts: £212.00
Below Goal: £38.00
85%
