Author Topic: Locomotive selection for my Mk3 push-pull set  (Read 430 times)
Offline BrakeCoach
  • Country: kr
    • BrakeCoachStudios
« on: October 03, 2018, 11:40:53 pm »
Hello,
I am finding an engine suitable for my Mk3 Push-pull set(DVT) in intercity swallow.
Currently it seems like the Class 90s are out, as well as the swallow 87s.
I am thinking to put a Railfreight Grey class 92 instead, but I am still unsure that it is able to do push-pull work.
What is suitable for a full intercity-liveried Mk3 push-pull set?
Are the 92s also able for push-pull?
Thanks.
Offline LeftToMyOwnDevices
  • N Gauge Society Number: 25806
  • Öand left to my own devices... I probably would...
Re: Locomotive selection for my Mk3 push-pull set
« Reply #1 on: October 03, 2018, 11:53:45 pm »
Hello,
Thanks.
I would seriously doubt that the Class 92 (when they arrive, or an existing CJM one) have push-pull equipment to work with a Mk3 DVT set.
However, you correctly say that an 87 or 90 would be suitable, if you can get hold of one (in the correct livery).
If you can hold off for a few months (or as long as it takes...), then there is this:
https://www.hattons.co.uk/274737/Dapol_2D_026_003_Class_86_2_86243_The_Boys_Brigade_in_Intercity_Executive_livery/StockDetail.aspx
As far as I am aware (and I'm sure others will correct me) a Class 86 would have operated with a Mk3 DVT set. Quite whether only certain sub-class(es) with TDM jumpers would, I'm not so sure.
Charles.
"Underground, Overground: Our friends Electric"
Offline Intercity
« Reply #2 on: October 04, 2018, 01:37:37 am »
An Intercity Mk3 rake from the mid 90s could have:
Class 86/1
Class 86/2
Class 86/4 (RES on hire)
Class 87/0 (87101 was an RFD loco I believe with ETH isolated)
Class 90/0 (001-015 in Intercity, 016-020 in RES, 021-024 in RFD/024 later painted into GNER blue) (90/1 locos had TDM cables removed and ETH isolated, they also lowered their top speed to 75mph, this was changed at a later date to restore them to the same specs as the rest of the class)
Class 91s were used with Mk4s, however when testing may have been seen with Mk3s albeit not in revenue service.
In later years EWS, RFD and FL class 90s could be used
Support crowdfunding - itís the way forward
Revolutions class 321 needs your help, letís make it happen.
Online MJKERR
  • N Gauge Society Number: X23832
« Reply #3 on: October 04, 2018, 06:14:50 am »
Priority was given to electric locos capable of 110mph
So you are looking for :
Class 86/1
Class 86/2 uprated to 110mph
Class 87/0
Class 87/1
Class 90
Class 90/0
On rare occasions one of the above locos was not available, so a Class 86/2 or 86/4 (prior to transfer to freight sector) would be used
Where such a set required a diesel loco due to a diversion in most cases the electric loco would not be included
Priority would be given to a Class 47/4
However, if the diversion was quite short then the electric loco would be included
If the diversion as less than one hour then typically any diesel loco could be used (Class 37 or Class 47)
Offline Karhedron
  • N Gauge Society Number: 19444
« Reply #4 on: October 04, 2018, 10:21:41 am »
I used to spot at Euston in the early 90s and 86s, 87s and 90s were all common on push-pull sets.
The Farish 87s and 90s are both fairly old but will do the job. My personal preference if you want collars and cuffs to match would be to look out for a Dapol 86 in Swallow livery. 86213 was code ND099b. It is out of production currently but 2nd hand examples turn up from time to time.
Although strictly speaking it should have had black window frames.
« Last Edit: October 04, 2018, 10:23:10 am by Karhedron »
Offline BrakeCoach
  • Country: kr
    • BrakeCoachStudios
« Reply #5 on: October 09, 2018, 10:57:15 am »
Class 86/1
Class 86/2
Another question, did RFD Class 86/4 ever pulled push-pull sets?
Offline Karhedron
« Reply #6 on: October 09, 2018, 11:05:41 am »
I think so. The picture below shows mainly Mk2 coaches but I believe these were still push-pull rakes with a Mk3 DVT at the end.
The shot below shows that Mk2 rakes were often coupled with Mk3 DVTs
« Last Edit: October 09, 2018, 11:11:04 am by Karhedron »
Offline The Q
« Reply #7 on: October 09, 2018, 02:01:47 pm »
How about A 37 and a 68 with a  MK 3 https://youtu.be/hy_d3o2jVxk,
Offline Intercity
« Reply #8 on: October 09, 2018, 04:35:17 pm »
During that time period the RFD class 86s could show up, but only for a failed shove capable engine, the RFD loco could only pull it had its TDM equipment isolated, the above picture I believe was a cross country service which did not use DVTs and only needed a pull loco.
Online crewearpley40
« Reply #9 on: October 09, 2018, 05:36:47 pm »
first the history lessons :
http://www.traintesting.com/MK3_DVT.htm
the edinburgh - north berwick used re allocated virgin wcml stock after the introduction of pendelinos
https://www.railforums.co.uk/threads/mk-3-dvt.130076/]https://www.railforums.co.uk/threads/mk-3-dvt.130076/
i have never seen a class 86 / 4 with a dvt, mainly 86 / 2, 87 and 90
« Last Edit: October 09, 2018, 06:27:45 pm by crewearpley40 »
Offline Intercity
« Reply #10 on: October 09, 2018, 06:14:38 pm »
I had a pair of 86/6s shove my Glasgow-Euston (1M31) once, although it was caused by the failure of 90008 which was on the front of the DVT due to a TDM failure, the 90 broke down at Penrith and was shoved into Eden Valley loop by the 86s on 4L?? Complete with its train of intermodel containers, once in the loop they backed out and ran down the mainline leaving us stranded, Intercity were kind enough to send 47853 from Crewe to rescue us (it worked the train all the way to Euston, we even got to watch 1M34 and 1M35 pass us we sat there that long)
But thatís not the kind of stuff the OP is looking for, just thought Iíd share.
« Reply #11 on: October 09, 2018, 06:31:36 pm »
not fun being stuck between penrith and shap on clifton junction
Online MJKERR
« Reply #12 on: October 09, 2018, 07:12:46 pm »
I do not remember any performing this
It is possible but more likely to be in pull only where a loco had failed and would then be replaced later in the day
Online MJKERR
« Reply #13 on: October 09, 2018, 07:18:56 pm »
Class 86/4 were used on Glasgow / Edinburgh - Birmingham services, and sadly this is one of those
At weekends it was quite common for the Freight livery 86/4 to be used, as they were spare
Equally, these locos shared both freight and parcels duties
For a short period the ETH was isolated, but this proved impractical so was reinstated (and same applied to the Class 90)
This all ended when the Cross Country franchise was awarded
Online MJKERR
« Reply #14 on: October 09, 2018, 07:19:38 pm »
Class 86/4 were used on Glasgow / Edinburgh - Birmingham services, and sadly this is one of those as the first coach is a RFO
