Author Topic: Graham Farish Class 40 With Sound  (Read 3127 times)
Offline Dr Al
  • Trade Count: (+49)
Re: Graham Farish Class 40 With Sound
« Reply #45 on: January 09, 2018, 04:25:15 pm »
Looks like it.
I suspect the DCC chip needs fairly close to the 12V to work properly on DC (After all, on DCC they run on 16v AC). I suspect on my WS the additional circuitry for the simulator causes a small drop, even when switched off, that doesn't bother DC locos whose motors are fed direct, but does this as the DCC chip needs to be powered, as does the speaker and it controls the power going to the actual motor.
I too thought my Castle was busted when I first ran it on this particular controller! (though I knew it'd worked before, so was able to figure this out quickly!).
You can always use the Kato controller to power layout lights or accessories.
Offline davidinyork
« Reply #46 on: January 09, 2018, 04:28:25 pm »
Is the available current also likely to be an issue? I've not looked to see whether the maximum which can be drawn varies much between different controllers.
Offline Dr Al
« Reply #47 on: January 09, 2018, 04:31:12 pm »
No. I have ammeters permanently wired to all my controllers, and they don't draw any significant current - way less than 100mA for the castle, 70mA for a DC Class 40. The current trip on the Gaugemaster controller is 1 AMP - i.e. at least 10x more than these draw.
Therefore it's voltage I think.
Total Receipts: £50.00
Below Goal: £5.00
91%
