Author Topic: My new locomotive works...  (Read 31789 times)
Offline R Marshall
  • N Gauge Society Number: 24052
Re: My new locomotive works...
« Reply #270 on: October 11, 2017, 03:45:46 pm »
I'd love to see some of these locomotives in the flesh (or 3D, or whatever).
That K3 looks great in grey, never mind when it's finished. And as for the V1/V3.............
How hard is the material you're using these days?
Roy
« Last Edit: October 11, 2017, 03:47:29 pm by R Marshall »
Offline paulprice
Offline paulprice
Online Atso
« Reply #275 on: October 11, 2017, 04:16:45 pm »
Just to prove that things have still been going on on the workbench...
It is difficult to see with that gloss finish but all the hand lining is complete, boiler bands, lettering and numbers will be completed using transfers now. Then it is handrails (shudders), buffers and final detailing to complete.
Online Atso
« Reply #276 on: October 11, 2017, 04:31:04 pm »
Roy
Hi Roy,
Sorry I missed this originally, many thanks for your kind words.
The N2 and V1 are Shapeways Frosted Extreme Detail which is reasonably hard but a little brittle. The K3 is printed on my machine in resin which can be post cured using UV light to a range of hardnesses depending how long you wish to expose the piece for. I like to keep a little flex in the print as I'm found taking it to an ultra hard state results in easy breakages and would say that it is comparable to a plastic injection moulded body but at the point where you would see plastic start to stress from bending, the resin will simply snap.
Hope this helps.
Offline Dr Al
  • Trade Count: (+49)
« Reply #277 on: October 11, 2017, 06:05:34 pm »
That's interesting. Does that mean there is a real risk of increasing brittleness in time as exposed to natural UV? I guess painted that should be minimised, but good to not leave in direct sunlight?
Online Atso
« Reply #278 on: October 11, 2017, 06:27:50 pm »
Hi Alan,
FUD/FXD and the resins used in SLA printers are all UV reactant and would continue to harden if exposed to a high intensity UV source without protection. Painted they should be as good as any other resin or thermoplastic in terms of lifespan but, like these other materials, will likely become more brittle as time goes on. My oldest FUD print must now be getting on for seven years old (if not more) and has so far exhibited no deterioration in it's condition while my oldest B9 print must be three years old now and again has shown no signs of deterioration. Both currently reside on a display shelf that is exposed to direct sunlight for several hours per day.
In a nutshell, painted you should be as safe as any other material.
Online Atso
« Reply #279 on: October 13, 2017, 04:57:57 pm »
A bit of an update on two of the locomotives...
Nearly finish cosmetically with a few extra details and weathering to still be done. The V1 is lagging behind a bit still.
Both the N2 and V1 still need to have their pickups sorted on the rear radial wheel...
Offline Train Waiting
  • The Table-Top Railway.
« Reply #280 on: October 13, 2017, 06:53:57 pm »
Thank you very much for these photographs of splendid-looking locomotives.
The little Stirling/Ivatt cab certainly accentuates the K3's massive boiler.
With all best wishes.
The Table-Top Railway is a train set trying and failing to be a model railway.
I believe that train sets and model railways are fun.
« Reply #281 on: October 13, 2017, 09:44:07 pm »
Marvellous modelling, Steve :drool:
Online Atso
« Reply #282 on: October 14, 2017, 07:09:40 pm »
Thank you guys.
I agree with you John that the GNR cab does emphasise the 6' boiler more than the later 'standard' cab did. It is interesting to compare the differences between the K3/1 and K3/3 and I had a couple of people asking if it was a K2 because of the cab at Wing today!
Online Atso
« Reply #283 on: October 26, 2017, 11:14:30 am »
Well while not posting, I have been working on a few bits and pieces in the background for a couple of other people since the weekend of the Wing and Peterborough exhibitions. However, needing a bit of a break, I've turned my attention back to one of the NQP Dapol A3s, that needed attention to the valve gear, that I purchased at the Dapol Open day.
Currently it looks like this:
Originally 'Grand Parade' she's been stripped of her identity and the vacuum ejector pipe and reversing gear has been removed from the left hand side of the locomotive and transplanted to the right hand side. I've still got some touch up repairs to do where I've removed these components but I think that overall the cosmetic surgery to date has been a success. One issue that had shown up however, is that the cylinders on this locomotive refuse to sit against the running plate properly. It would appear that the previous owner attempted to glue these into place (badly) resulting in a lip forming that prevents the cylinder assembly clipping to the running plate as it should. Therefore, I'm going to have to do what I hoped to avoid and strip the locomotive back so that I can get into the affected area and remove the glue. The glue is obviously not the same type that Dapol uses which is why I'm leaning towards this being the work of the previous owner before they returned the locomotive.
If anyone is interested, this one is likely to become Harvester in mid 1930's condition. I've have two pictures of this locomotive, the first is dated 1928 and she is shown paired with a corridor tender. However, it appears that she lost this at some point as the picture dated 1932 shows her with a GNR tender as per my donor model (or should that be victim?  >:D ).
Offline R Marshall
« Reply #284 on: October 26, 2017, 08:11:29 pm »
Steve,
RCTS Part 2A table (summary of A1 and A3) shows 2573 Harvester, built in October 1924, as having a GNR type tender with coal rails initially, changed to a corridor tender in April 1928, but reverting to a GNR type from July 1928.
Figure 86 in that volume shows her in May 1932 with that tender, near Darlington with the down Flying Scotsman. Figure 84 shows her near Inverkeithing on clearance trials in July 1928, with the corridor tender.
Roy
