Author Topic: Track building  (Read 430 times)
Offline mattcaney
Track building
« on: April 24, 2017, 12:30:58 am »
Have track in place and tested whats the next stage have weathered rails. Ballast then nail track down ?
Offline njee20
Re: Track building
« Reply #1 on: April 24, 2017, 05:12:42 am »
No point nailing track once you've ballasted, it won't go anywhere.
There's no right order really. I'd put all your signals in before ballasting.
Offline LAandNQFan
Re: Track building
« Reply #2 on: April 24, 2017, 07:48:05 am »
Should you wire before ballasting, in case anything needs to be changed?  My soldering is so clumsy that a pile of ballast is often needed for camouflage!  :-[
Perhaps the proof that there is intelligent life in outer space is that they haven't contacted us.
Layout thread: http://www.ngaugeforum.co.uk/SMFN/index.php?topic=23416
Re: Track building
« Reply #3 on: April 24, 2017, 08:03:23 am »
It's much easier to solder track feeds, etc. before ballasting.
Offline njee20
Re: Track building
« Reply #4 on: April 24, 2017, 08:03:28 am »
Definitely do all your wiring before ballasting, AFAIK Matt's done that. I'd probably leave it a bit longer to make sure it all works though.
Re: Track building
« Reply #5 on: April 24, 2017, 08:08:43 am »
If the track is set track and it's not going anywhere, then yes, no need to use pins at all.
I used pins on the sweeping flex track curves on the branchline of my layout, but removed them after ballasting.
Offline daveg
Re: Track building
« Reply #6 on: April 24, 2017, 08:15:32 am »
Virtually all my track is down and fixed with Copydex but after 18+ months I've yet to start ballasting; but I have ordered the stuff over the weekend!  :worried:
Offline njee20
Re: Track building
« Reply #7 on: April 24, 2017, 09:52:05 am »
Yep, same, and likely to remain so for a good while yet!
Offline Karhedron
  • N Gauge Society Number: 19444
Re: Track building
« Reply #8 on: April 24, 2017, 03:15:49 pm »
I also used copydex to glue the track down rather than pinning it. Several years on it is still where I first put it. ;) I normally work in the following order.
1. Lay track (including any isolating sections you may need at this stage).
2. Wiring (including soldering).
3. Weather track (you can be quite crude at this stage, I just blasted everything with Railmatch Sleeper Grime and then wiped the rail stops clean).
4. Ballast.
5. Final weathering to weather the ballast and tone the whole area in with its surroundings.
Offline mattcaney
Re: Track building
« Reply #9 on: April 24, 2017, 03:30:58 pm »
I am having trouble with putting a dapol coupling into a new Graffer Tornado. doesnt seem to fit, its looks like the same type but maybe I haven't got the knack of putting them in. What to try out my magnets.
Offline njee20
Re: Track building
« Reply #10 on: April 24, 2017, 04:48:55 pm »
Yes, the Farish A1 has NEM couplings, Dapol 'pips' can be a little larger, a tiny swipe with a file can help. Holding the coupling with pliers can also help, but you risk deforming the coupling box.
Offline nick_bastable
  • 2mm Association Number: 3935
Re: Track building
« Reply #11 on: April 24, 2017, 07:28:05 pm »
lay / build track
wire
Test
test
TEST
Test
paint
Test
Ballast
Clean up
Play
Nick
Offline RailGooner
Re: Track building
« Reply #12 on: April 24, 2017, 07:40:00 pm »
Try this Matt...
http://www.ngaugeforum.co.uk/SMFN/index.php?topic=36354.msg443329#msg443329
EDIT
Sorry Matt, you've 'thanked' that post so have obviously read it. Did you not have any joy with that trick?
/EDIT
« Last Edit: April 24, 2017, 07:42:39 pm by RailGooner »
Offline MrDobilina
Re: Track building
« Reply #13 on: April 25, 2017, 01:32:40 pm »
lay / build track
wire
Test
test
TEST
Test
paint
Test
Ballast
Clean up
Play
Nick
you missed a test after the ballast bit ;)
Online austinbob
  • N Gauge Society Number: 23835
Re: Track building
« Reply #14 on: April 25, 2017, 01:51:24 pm »
And you missed the 'fix' after 'play'...
And then, of course, another 'test'.
« Last Edit: April 25, 2017, 01:52:59 pm by austinbob »
Bob Austin
